Parts...Parts...Parts...
I need rear seat belts for a 76 k5 in burgundy, and the spare tire bolts that hold the spare tire to the hanger for a k5 as well.
If you would have asked a month ago, I had the seat belts. I'll check on the spare tire bolts
hunter78
Maryland
Hunter
350 4-bolt main
Do you happen to have a good 3 piece frame crossmember, the one that's located right after the cab? Mine's a 78 k10 and is rotted out and same goes for all the local parts yards
Sent from my E6782 using Tapatalk
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Happen to have a driver side AC bracket and power steering pump bracket?
hunter78
Maryland
Hunter
350 4-bolt main
No thank you just need the one particular frame cross member
Ray9734
Washington St.
Raymond
Camper Special
Do you have Power steering brackets? You cant imagine how awesome you would be if you had some.
SBC? or BBC... Yes I do.
Ray9734
Washington St.
Raymond
Camper Special
SBC. I'm wondering if other chevy mounts will work. Y'know Camaro, Malibu, etc. I cant find anything in the wrecking yards locally.
Yes they should be the same, as long as it is a SBC
moorevisual
Atlanta
Do you happen to have the left and right grille supports for a 1979 c10?
Cool thanks
I haven't forgot about you. I thought I had a set somewhere. I have a set on the 80 core support, but that is kinda hard to find, since it was just a single year release.
moorevisual
Atlanta
no worries, i just found some on ebay for a reasonable price. thanks for checking though!
loki1978
