Overdrive not working
Sweden
Andreas
I have a 1983 C20 with 6.2 diesel and TH700, wher the OD dont work anymore. The OD is just powered by a single green wire. Any idea what has happened? It have worked fine for many years but suddenly wont step in. Where to start fault-finding?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Brake switch, there's a vacuum switch as well as it's hose to check on the firewall, and a few wires to check running from the trans.
I guess I'm not positive on the vacuum switch because it's a diesel.
scrap--metal
MN
Calvin
'85, '81
K10, K20
An issue with the brake switch would prevent the torque converter from locking up while in overdrive, but I don't think that would prevent the transmission from shifting into overdrive.
Perhaps that's what the OP meant?
PrairieDrifter
North Dakota
Mason
I think he can get it into overdrive it just won't activate.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The overdrive on a 700 is hydraulic, nothing electrical. If your referring to the lockup converter, that is electrical.
Start with checking for power on the purple wire at the brake switch. It should have power with the key on, push the brake pedal and it should go out.
The purple wire supplies power to the solenoid, I have no clue what controls the ground side of the solenoid with a Diesel engine. There is a 4th gear pressure switch in on the valve body to tell the computer the trans is in 4th, I’m guessing there is a speed sensor and some kind of module to detect engine load to lock/unlock the converter.
scrap--metal
MN
Calvin
'85, '81
K10, K20
That's the vacuum switch on the firewall that @PrairieDrifter previously mentioned. That and the brake switch are the only two things I can think of that control the lock-up converter on a 700-R4.
Sweden
Andreas
No vacuum is involved because its a diesel. Thing is that I have added a switch witch prevents the OD to step in until I want and I just want it once on the fourth gear. Without that switch, it jumps in on every gear. The switch is just in line with the single green wire going down to the trans. I have checked that it's power on the cable. It must be a coil/solenoid inside the trans that once energized controls a valve? Anyone who can explain how this works?
PrairieDrifter
North Dakota
Mason
Here's the solenoid, before and after I swapped in the painless kit. This would be the guy that controls lockup.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Unless it's been fooled with there is definitely vacuum involved with diesels. They have a vacuum pump on the engine and there is usually a vacuum and/or electric throttle position sensor on the injection pump.
I don't know if that has anything to do with the lockup issue. It's been a long time since I fiddled with a 700, but GM didn't convert the whole truck to electric just because they put a diesel in it.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
There is for SURE no vacuum involvement for a 700r4. The th400 uses vacuum to control shift points and has a valve on the throttle linkage at the injection pump for control vacuum signal to the modulator at the trans.
Another thing. The OP needs to stop saying his overdrive isn’t kicking in unless he hits the switch. He’s controlling converter lockup. So from that, I’m guessing he has a converter lockup issue not overdrive issue.
Ben
PrairieDrifter
North Dakota
Mason
Ben
No vacuum directly to the trans, but vacuum is involved for lockup to operate properly.
Also agree. 4th gear is operating it's just not locking up the converter. Which would either be the servo, pressure switch or the vacuum operated torque converter switch or related wiring.
Itali83
Maine
Ben
My words guys. The 6.2 does not use ANY VACUUM OF ANY SORTS for the 700r4 transmission or it’s converter. The vacuum converter switch was only for the gas jobs. The 6.2’s have an electric throttle position switch on the injection pump that will lock and unlock the converter depending on throttle position.
Not saying I know everything but I’m tellin’ you. Forget about vacuum with this truck and it’s converter.
Ben
wlwarnke
Helotes, TX
William
Here’s my old sketch from when mine was stock with a 6.2.
No vacuum.
wlwarnke
Helotes, TX
William
No vacuum.
Dotted line is inside the Tranny.
I believe the test terminal was under the dash.
Itali83
Maine
Ben
Test terminal is outside of firewall by brake booster.
Ben
78ALB
