Lifted1
- Mar 27, 2017
- here
- Yup
Hello,
I'm having gauge problems in a 1983 GMC High Sierra C1500 i just bought for my daily driver.
basically the only thing working on my cluster is the speedo and clock.
the only obvious ground wire i see coming off the back of cluster is black and attached from clock to bus bar. the clock is powered separately as well.
a test light on all pink wires on gauge plug show the #7 and #18(which is pigtailed in) have no power. all other pink wires are hot.
does anyone know where these pink wires are supposed to be getting power from? is there a fuse in line or in the fuse box that i should be checking?
i pulled every fuse in the panel and they are all good. i cleaned connections and put back and nothing....
pulled the fuse block on firewall and its clean as can be.
water temp sensor is new and i've inspected the green temp wire and its not grounded or melted anywhere.
i pulled the ground from cab to engine block and cleaned it up. no go.
i'm stumped?
gas gauge does not work either.
does anyone have any suggestions?
i'm stumped?
