Oil pressure gauge
Jerry phillion
Saginaw, mi.
are all orig dash gauges electrical or is the oil pressure gauge mechanical ? My PO has replaced my oil
Gauge with a mechanical one. He put the oil gauge in the spacE where a clock would go. I want to
Replace that gauge with a new orig one in the orig place. Any thing I should know before doing this?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Factory is electrical. You would need the sender and if not originally equipped you would need to fine the wiring. Just curious tho why remove a mechanical gauge?
CSFJ
Probably doesn't want hot oil piped into the cab, or to match the factory gauges?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Meh if you use the copper line you should be good not that plastic **** that's just asking for trouble. Lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
My 72 had a mechanical gauge from the factory and it came with copper line.
That's what I thought the older stuff was mechanical. So much better and way more accurate.
CSFJ
When I was into import racing, we used an a/n bulkhead fitting to pass through the firewall and then braided stainless line to run to the gauge. Iirc, the mech gauges cost less which I'm sure was the driving force behind our use at the time.
Jerry phillion
Saginaw, mi.
Guys, I just want to restore dash to orig, beside I believe the
Mech gauge is not right. The orig gauge is still in dash. I don't
Know if it is any good or not. I will get new gauge, put in new
Brighter bulbs and repaint the surround.
Also, where is the sending unit located for orig gauge and what
color wire should l look for?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Brown and behind the distributor. It was probably removed to install manual gauge. Find the brown wire. Turn the ignition on and ground the brown wire. If your gauge goes to zero it might be ok. And absence of ground will peg it.
74 Shortbed
That is actually the best and safest way to do it, cost might of been part of it but I think reliability was the biggest factor, didn't have an electric sensor to take a **** on ya at 7500+r's and the gauge still read 80lbs when you really had only 10lbs...
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Just make sure to use loctite 545 hydraulic sealant on the threads from the copper line to the back of the gauge. Nothing worse than an oil leak behind the dash, or even into the face of the gauge. Don't use teflon tape. I use loctite on all of my airline fittings for my air ride setup...no leaks..ever.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
They use compression fittings?
smoothandlow84
Steve
No compression fittings on air ride, but this same thread sealant is far bettern than teflon, even when used on compression fittings. A small droo is all thats needed to seal the threads
Jay Don
