Octane?
Stepside Billy
Lake Carmel, N.Y.
Billy
Maybe a dumb question but with a 1987 350 TBI with a few miles should I run a higher octane gas? Not sure if would make a difference. Truck runs good as is but don't know if it's worth the extra money. Thanks!
yevgenievich
Viktor
sad
very sad
less sad
It would not make a difference without a tune
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
I can get 89 octane ethanol free around here. I run that and get waaaay better gas mileage than with the 87 octane E15. Just a thought if you have access to E0 gas
87scotty
Central il
Andrew
V20
5.7 for now
Well that must be nice
SkinnyG
Canada, eh?!
G
C10 Silverado
350/TH350
If it runs fine on the cheap stuff, run the cheap stuff. Unless there is a problem (ie: your engine is built for higher octane), you would be throwing money away.
You will make the most power on the lowest octane you can safely run.
Don't get sucked into fuel company marketing.
Stepside Billy
Lake Carmel, N.Y.
Billy
Thanks all. I figured I'd ask seeing I haven't had anything older than a '99 Dakota in a while!
Driver4r
Nebraska
Trevor
k10,c20
ACTUALLY, with more octane come more resistance to combustion, which means you can add more timing without it detonating. Which in turn WILL make more power. But in a bone stock sbc. I would just run the 87-89. I run 89(e10) in my 355 in my truck. 10:1 flat tops, with a cam. But your TBI should have a knock sensor that it will use to adjust the spark advance acordingly.
blazerguy33
