nv450+468c.i.= booom?
oreopenguin536
Reno Nv
Brett
307?
well thanks for all the help!
All those manuals listed above have granny low right?
yevgenievich
Viktor
sad
very sad
less sad
oreopenguin536
Reno Nv
Brett
307?
Gonna be a epic read. Thanks for the link! That Zf-s6-650 sounds like a BEEASSTT
marks86
Latham, NY
Mark
12v Cummins
ive seen a guy install a zf into his truck he had to recreate his entire transmission tunnel
yevgenievich
Viktor
sad
very sad
less sad
I would think it should fit on 4wd body with 1-2" body lift
marks86
Latham, NY
Mark
12v Cummins
personally I don't think a zf-6 or a nv5600 are worth the money. Its not like you get an extra overdrive gear compared to a nv4500 its like a .73(nv4500) .76(zf)
oreopenguin536
Reno Nv
Brett
307?
I got a 4 inch lift.... ok, so I have another question...if you refer the truck for 33 or 35s and have a big block can you still get decent milage? With the new gearing
highdesertrange
kalifornia
mike
k30
no decent mileage with a big block. no matter what tire you have. highdesertranger
oreopenguin536
Reno Nv
Brett
307?
even with sufficient gearing? like no matter what at all
CSFJ
Even with a mast and a sail mounted in the bed.
oreopenguin536
Reno Nv
Brett
307?
lmfao
wait bad being like 18 highway right? or bad as in like 10
CSFJ
doubt you'd see 10 going downhill with a tailwind.
yevgenievich
Viktor
sad
very sad
less sad
I had 97 1 ton with big block and it consistently got 16-17 mpg on the highway mildly loaded and 12 with a trailer(6k pounds). In the city with not much traffic it would do 14mpg. It had the nv4500
highdesertrange
kalifornia
mike
k30
with a square and a big block you will be lucky to get 10. didn't you say you wanted 500-650hp or was that someone else? if that's the case you will be lucky to see 5. highdesertranger
oreopenguin536
Reno Nv
Brett
307?
yea, i wanted to see 500-650 but I forgot that I had to gear the truck, once its geared ill have the same affect I'm thinking, when its geared ill only put a cam, intake manifold, exhaust and heads and call it a day for now, I at least till i can get a bike again or a cheap daily driver
Garcjay
