Np208 transfer case brace
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Does the thing actually do much? It makes it a tight fit for the exhaust so I’m on the fence about removing it. If it doesn’t do much I’ll take it off for the exhaust clearance, the exhaust is right where I pretty much want it. I don’t want it any closer to the frame rail. So at this point the brace is in the way.
Maybe I can bend it away? Or maybe cut it at the end by the trans and modify the eye to sit the opposite way and then weld a sleeve on the outside?
PrairieDrifter
North Dakota
Mason
This guy
SDJunkMan
Black Hills of South Dakota
Jeff
This guy
If you aren't talking about the one that goes up to the front of the engine, I would keep it.
The PO of my K20 left that brace and the cast torque converter cover and braces off mine before I got it, and I broke the bellhousing in half. Granted, I used the truck as a snow plow, and was never gentle with it.
QBuff02
Central IL
Quincy
I would move that hangar and modify the exhaust before I'd go removing the truss rods, bad juju generally follows from my experience.
QBuff02
Central IL
Quincy
and I guess another thing, if you wanted to keep the exhaust tube right where it is, you could always heat it up cherry red and "clearance" the tube between the two for the truss rod to get by it and remove the interference. Now, I have full length headers and 2 1/2" tubes on mine, and My exhaust has a few slight bends to get by/around the rod on mine and even though its not ideal, I'd put up with a modified or rebent exhaust tube before anything else. just my .02
hatzie
k20
You will break bellhousings without that brace. You need it.
I broke a later bell pattern NV4500 Bell before I wised up and installed the NP208C to Bell brace on my 76 K20 6.5L project. I had a small panic attack when I thought it was the engine side cracked on my pristine 1998 6.5L TD block that I'd spent some good money installing a main girdle on.
My M1008 came to me from the DRMO depot without one.
Guess what I replaced along with replacing the missing 27MT starter tail brace?
The 6.xL AMG GM diesels have braces, or truss rods, from the motor mounts to the bellhousing as well. I haven't had the balls to leave them off since my small heart attack over the broken bell. Breaking the thin bell casting area on a working 6.2L or 6.5L block would suck. I would probably consider adding them to a gasser that I intended to plow with or otherwise abuse.
PrairieDrifter
North Dakota
Mason
Alright, well looks like it’s gonna be staying and I’ll be modifying the exhaust then lol. I think I might just clearance it, there’s not too much interference goin on.
I also did remove those transmission dust cover braces, because I got different motor mounts. But I’m thinking I should probably get some stuff modified to put those back on.
Thanks for the replies guys
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Mine is bolted right to the frame. Then again it’s all solid mounted.
PrairieDrifter
North Dakota
Mason
I think mine had plates that bolted on underneath the motor mounts then they ran from the cover to those plates
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Originally it would have. One on each side.
rpcraft
Robert
LS 6.0 364 CID
I've been contemplating whether to put mine back on but with the LS swap it's probably going to complicate things. Once I get to my new house and can get the garage set back up to work in I'll dig into it a little more and see what I can fit in. Gonna be nice to be able to zoom around on the creeper with the new 2 car garage!!!!
hatzie
k20
That's the way mine are.
That's the right call. Keep it !!! Orr, figure out something else that serves the same purpose, but I think that one is your best option since trying to figure out a way to anchor the Tcase tot he frame rail will put that directly in the path of your exhaust.
PrairieDrifter
North Dakota
Mason
What do you guys think about fabbing up a new brace and running it straight to the crossmember? Probably a triangular style, still be able to unbolt everything easy if need be. Something in the future probably, I’ll probably change it up a little bit from the H-pipe forward.
I think I’m gonna do headers someday soon I just want a really nice set so I’m saving up. So I’m gonna have to change that pipe up a little bit anyways. So I can get a better fitment then.
For now though I’m fine with “massaging” the pipe in the problem spot lol
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Unless you solid mount everything to the frame you're probably going to add stress because the engine, transmission and transfer case all move as a unit in the motor mounts. That's also why your exhaust is in flexible mounts. All that stuff wiggles around quite a bit and needs to all move together. Rearranging an exhaust pipe is much easier than re-engineering the powertrain.
bigboytko
