No tail lights or cluster lights
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
O look! It's the same as his signature.
Yeah, on my end I see no signature.
I did try looking for something before asking.
Thanks BlueOX. Very appropriate but even more appropriate would be jacka$$ Jim.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
It is on his profile, but it's smart not to @$$ume. Plenty of people here have multiple vehicles or are working on something they don't own.
Trogdor
Ohio
Ian
Scottsdale
Yeah, that’s my fault. I should’ve stated it at the beginning.
Trogdor
Ohio
Ian
Scottsdale
All right. Did some more poking around shortly after I got home. Used a test light on the gauge harness and position 1 and 2 are getting power so am I right to assume the Inst lights are getting power even though they’re not actually lit up? What does this mean?
Also, found the orange and white wire that run to the back of the cab running from the fuse block. Using the test light the orange is getting power but not the white. Should they both begetting power?
I also changed the bulbs in the taillights with nothing new and using the test light on the sockets and got nothing.
73c20jim
Tombstone, AZ
It's a ******' joke. Lighten up!
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I tried to diffuse it with humor. We can see how that worked out. :rolleyes:
73c20jim
Tombstone, AZ
Need to write a book "Sarcasm for beginners."
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Sorry dude, didn't see it as sarcasm. Moving on.
A good idea is to print out those schematics for the lights. Then mark what & where you've checked and what results were.
Orange is power out from headlight switch to light up interior light only when dome switched on or with door open. Good bright test light? Make sure to test with door closed or remove that door switch, so you're not getting skewed readings.
White is the ground side to that same circuit. Should be hot once dome is switched on, because it's completing the circuit. You said this wasn't lit? Move test light clamp to battery positive and check for a good ground on that white wire with the dome switch OFF. Should light. Otherwise this is 1 issue.
All I'm focusing on right now is the headlight switch and the lack of parking lights
Trogdor
Ohio
Ian
Scottsdale
Diddled around some more this morning. Light blue and dark blue (15 and 20) aren’t getting power. Checked fuse and it’s good, replaced it anyway to no avail. I’m guessing now that I have a bad connection of sorts to the fuse block. Could I be wrong in this assumption as my front indicators, low and high beams still work?
I’ve pored over multiple wiring diagrams and the schematics. I’m really at a loss.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The circuit list says the 15 is front RH directional lamps and 20 is the stop lamps. You say they work. I think you're looking for circuit 9 for taillights and rear side markers. Also, there are plug connectors in the harness back there that you'll want to check.
Trogdor
Ohio
Ian
Scottsdale
Well... I clearly missed that one. :suicide:
scawdrey
