No Start...
Ashton84W
Ashton
I swear if ain't one thing, it's another... Well I'm back with another problem- well multiply problems. So here I am enjoying my hash browns at Waffle House, just chilling. I get up to leave and I go out to start my truck.
I here a click from the starter gear coming out and meshing with the flywheel then nothing. I lose ALL power to everything. I lose power from all my gauges and headlights to my stereo. It's EVERYTHING. Because of this, my truck has been sitting at Waffle House since Saturday. From what I thought to try and reasearched, I have done...
  1. Cleaned and checked all connections on the battery and starter side and made sure there tight...
  2. Had the starter bench tested although not under load (high torque mini starter)...
  3. Had the battery charged and tested (have two that I've been using)...
  4. Checked all grounds (although I may have missed some)...
  5. I dropped the tilt steering colum and replaced the ignition switch with one from AutoZone (don't like them but eh)...
  6. Sure I missing something but did other stuff to...
So what do I need to do now? Not tech/ electrical savvy what so ever but kinda need help here. My plan is to replace the steering tilt colum because it had broke somewhere in there since my power steering pump went out and it finally just couldn't take the stess anymore BUT it's been like that for about a month now. Anyone had this problem before? Any suggestions? Thanks y'all...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Did you check the fusible links at the starter on the wires that feed the junction block on the firewall that feeds the inside of the truck. The fusible links are down at the starter.
Ashton84W
Ashton
I had thought about those but I don't know how to test them. Forgot to mention them in my post. Could those be the culprit???
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Good possibility. I'd cut them out and install new inline fuses. Be sure to disconnect the negative battery terminal when doing it.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I'd try that, too. Did you throw away the old ignition switch? It's probably better quality than the Duralast one unless it was one, too, or MasterPro. Ick.
Gord
