newer bench in to a k10?
boostscootinboogie
CT
K10 shortbed
can someone post picks and how to for putting a 89-94ish bench seat in to the 85? i know the k10 brackets have to be used and maybe modded and i seen them in trucks im guessing it is not that hard but to make it easy if someone did one and can run it down maybe some underside pics would help alot. thanks
muddyman184
Phila
steve
90 AND 82
K5,K20
I dont have any pics but my buddy had a 95 bench in his 77 and he said he made a bracket on the 95 bench bracket to bolt in bottom line is he reused the old holes in the floor with a bracket to the new bench. Im looking for a newer seat for mine and going to do the same thing
adriner
Out in the sticks, PA
Adam
k25, c20
350 nv3500, 6.2TD th400
I don't have pics of my brackets but here's my 60/40 in my 79
All I did was make a rectangle bracket from 2" square tubing, bolted to seat then to brackets took about an hour to do
:popcorn:
muddnutz
Canton/Holly Springs Ga
k-10
gm crate 350
I have one in my truck. Easy install. Had to use tracks from 86 on 95 bench. Drill two holes I believe. Will have to get pics when its not raining
aaron06
