NEW window/lock harness vs OEM
Darkrider
Lloydminster Sk Canada
Custom Deluxe/Sierra
Sorry for digging this up but i just need to clarify things. So basically using your harnesses all i would need from that point would be the doors with the power windows and locks in them?
gmachinz
Harnessworx Inc
Iowa
Jabin
Correct-I also stock:
New cab/door boots
*New GM NOS lock relay
*the factory relay is obsolete but I stock NOS GM lock relays that are an interchange for the truck ones-they will work also.
Darkrider
New cab/door boots
Nice! I may be talking to you in the near future then about ordering one. The doors are in rough shape on my '84 and i pretty much decided a couple days ago that when i go scavenging for parts from the burbs at my buddies place i am going to grab the doors as well especially if they are power window/power lock. Not quite sure what i am going to use the rear door switches for on the drivers door but eh..i am sure i will sort out some alternate use for them. :headbang:
gmachinz
Harnessworx Inc
Iowa
Jabin
What color is your interior going to be?
Darkrider
More then likely plastic hard parts like the door panel and the dash pad will end up black while everything else will more then likely remain the light blue they are now.
xXmutantXx
