itscaleb
- Nov 3, 2015
- Tinker AFB, Oklahoma
- Caleb
- K10
I wanted some of you vets opinion on my new investment/project.
I bought the truck for $500 knowing the transmission was probably bad. It would go in reverse, but not drive. I put it in drive and I can hear the engine rpm's drop and can feel it engage but it won't go forward. When I got it, I checked the fluid levels and they were WAY WAY WAY too high (almost 1/3 the way up the dipstick, cold) dark, and smelt burnt. I was tempted to put a new filter on and put the pan back on and put the correct amount of fluid in it and see if the fluid level caused the issue, but I figured with the condition of the old fluid, it probably has something else wrong.
I also did some other research on it and im not sure if its a good combination or not, but I believe it has the 305 v8/th350/NP241C/GM 10 bolt (which is leaking). After reading the 700r4 to th350 4x4 thread, I went and looked and it has that conversion spacer. I'm not sure if they did the same thing as in the thread with the output shaft, cutting off 1 1/2 in, but I know it was running fine till the transmission stopped working.
I've attached a few pictures. Any insite would be greatly appreciated.
Caleb
Caleb
