Neutral Saftey Switch
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
Need to install Neutral Safety Switch on "87" to pass Canadian Inspection
Auto to Super T-10 any suggestions on which wires would be appreciated
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Find the clutch pedal switch at a yard and run your automatic neutral safety switch wires threw it. That's how the factory did it threw the clutch pedal. And very nice truck you got there and welcome to the site.
74 Shortbed
Welcome to the site, very nice truck indeed..
chengny
By 1987 the neutral safety switch (formerly used with automatic transmissions) was history - 1984 was the last year I think.
It was replaced with a mechanical interlock in the column that prevented the ignition lock from being turned to the START position unless the gearshift was in P/N. The combination NSS/BU light switch became just a BU light switch. The NSS contacts -and the wiring that connected them - were eliminated from the harness.
On the other hand, trucks equipped with a manual transmission continued to be fitted with the "clutch start interlock" switch. But seeing as your truck came out of the factory with an A/T, that switch and the associated wiring won't be there.
So, since you won't find wiring for either a CSS or a NSS in your truck, you will need to splice a CSS into the lead that runs from the ignition switch to the starter solenoid. For trucks originally equipped with an A/T - and from MY 1985 and up - there is a purple wire that runs straight from the ignition to the solenoid.
So, after you source a clutch safety switch (and find a way to actuate it with the clutch pedal) all you have to do is cut the purple lead and insert the CSS wiring/switch.
The PPL 6 circuit (one wire) will be in the bundle with a yellow tracer:
I'm severely color deficient but, going by it's location on the ignition switch, I am fairly certain the yellow arrow is pointing to the wire you need to splice the new CSS into.
This image shows it better (disregard the yellow circle and line):
A wiring diagram of what needs to be done:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
My 87 has a switch at the base of the column for the reverse lights and I was assuming the green wires were for the neutral safety switch....I ran the reverse light wires threw my floor shifter and left the others alone. A clutch pedal switch could be added to interrupt the starter lead from the ignition switch inside and activate it when the pedal is pressed. It's not fancy but effective.
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
Thanks for the informative reply
I think I will spend time on this forum
I do NOT know everything and gobble up knowledge about CHEVY anything, and am willing to advance the knowledge to others.
This is my 2nd square body, my first one I had for 28 yrs.
Thanks again
Zoomalot
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
What did you end up using to solve your issue? I am in the same boat with a auto converted to a manual. My clutch pedal does not have a switch, not do I see anywhere to attach one.
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
Ended up using simple plunger switch on clutch pedal spliced into PPL as per diagram on this page.
Buy a good quality plunger switch as some are crap.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I guess I don't know a part number for a "simple plunger switch".
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
Sending you a Switch Supplier site, there are tons. Bend some metal and drill holes for a mount on the clutch/brake pedal
mechanism and splice through wires on the diagram. Just stay away from plastic type of plunger switch as they won't take
the repeated on/off motion of clutch pedal engaging and disengaging.
  • Rugged Plunger Limit Switch | CPI J4401-514 Plunger Switch | CPI (dragged).pdf
jodygraham64
