Neutral Safety Switch
Grandpa Hilljack
Oklahoma
Carl
Does this tab go under/inside the column to help hold it in place somehow?
I have an 82 C10 that I’m fighting putting this new switch on. I can get everything into place and plugged in fine. But as said as I move the shifter it tries to pop up out of where it sits. I have the tab where it goes into the column so it’s set right.
I have the 2 screws that hold it in tight. It’s like it’s not setting in there exactly right. I’m frustrated beyond belief.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
That tab fits into a slot on the shift tube - your old one did not break off and the piece is still in there, is it ?
I'd that's OK, compare the new to the old.
Same dimensions? In other words, is your new one the correct part ?
If none of those are it, try installing it with the column in neutral and that tab centered.
Cant say I recall seeing this issue before so just throwing ideas at ya.
Grandpa Hilljack
Oklahoma
Carl
I’ll try and see if I can see that tab. The column was swapped at some point in its life. I thought this would be pretty straightforward. But it has tested me to the end lol. Thanks for the response. I’ll let you know what I find.
Grandpa Hilljack
Oklahoma
Carl
Well no luck finding the slot that fit in. After a couple of hours cussing, I wound up using a hose clamp tightened to hell and back around it. Is it factory? Nope. Does it work? Yep and I have reverse lights now.
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
I’m struggling with reinstalling this I can’t get it to catch the steering Collum tab holes, is it safe to drive with just the wires dangling to the safety switch?
Snips71
