Need help identifying this squeak. Maybe bearing, maybe speedo?
jmcclane55
Dallas
I'm leaning towards speedo cable. I put the camera on all 4 corners and it's loudest over this wheel (driver rear), and second loudest over driver front. I can hear it well in the cab with the windows rolled up. Makes the sound in gear and out. With brakes and without.
Skip to 1:50 or so.
https://youtu.be/G9YfmB4pgzo
Georgeb
Wisconsin
George
K10 Burb Z71
I would suggest you disconnect the speedo at the trans and go for a spin. If it is still there it sounds like a U-joint squeak to me.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Just pop the drive shafts out real quick and see if the caps that you can take off, look if they're rusty or dry
MannyDantyla
Lawrence, KS
Danny
sbc350/sm365/np205
easier to start with the speedo, IMO
jmcclane55
Dallas
Connected to my trans is a stewart warner speedo reducer (because it's impossible to get the right drive and driven gears for my rear end), which I thought might be it. I disconnected the speedo wire from it and the sound went away. I picked up a new speedo wire yesterday and will install it.
I needed to take the cluster out anyway for some R&R. so I guess it all works out. :)
johnalen76
