Need help. Can’t find temp gauge sensor on 1984 g3500 Vandura
vandurA
illinois
nieal
Hi all,
I’m new to this site and joined because a lot of good info is only found here.
I have a new to me RV motorhome. The front end is a 1984 gmc vandura g3500 5.7L A/T.
I’ve only driven it a couple times and now the temperature gauge always reads low maybe about 10% off from the lowest. This wasn’t the case the first time I drove it .
So I’m looking to change the temp gauge Sensor. I looked for around a half hour after looking back and forth for pics to get an idea where it is but for the life of me cannot find it. Here’s a pic to get an idea. There’s not a whole lot room to work with but I looked all over the block, traced the cooling system down as best I could and tried to look at any harness wires knowing what the sensor should look like, but no luck . I’m hoping someone who knows this system better can give some advice as I feel like I’m looking in the wrong spot but everything online suggests it’s the right area to look. Thanks in advance.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
It should be a single green wire going to the front driver side head. Between number 1 and 3 exhaust ports. 15/16 socket I believe. Good luck! I hate working on vans with a burning passion.
vandurA
illinois
nieal
Thank you, I’ll take a look again. Yes this is my first time working this can and I can see why you hate it. Even taking the battery out had some small challenges.
PrairieDrifter
North Dakota
Mason
It may be near the thermostat on a van if not in the head, there's also a possible spot on the passenger head between 6 and 8.
I've worked on more motor homes than vans. But have done both many times, pulled quite a few engines as well. I'd really love to have an old van, but wow I would not want to build/maintain one, old new, doesn't matter.
DucatiDave
