Need help!! Camper Special Option Details
builtnotbought
bc
mike
k2500
6.2 diesel
im wondering what is so special about my truck, its an 86 gmc k20 campers special high sierra what camper special mean and whats so special about the high sierra. One more thing my power steering and brakes dont work. just replaced ps pump and nuthing would this be my hydro boost??
thanks, mike
I'm gonna fix this up so you get help Mike. NO shortage on threads around here, so try to keep your topics in the right categories. It not only gets you the best help, it help others find the same info. Try to title a thread pertaining to your issue also is a big help. Many times, the people who help just zero in on what they feel confident about and you'd get skipped with a vague title like "Need Help" I'm seperating your questions into their respective categories. Help will be along much quicker this way.
Your steering and brakes thread went here. Be sure to make a post there so you are subscribed and can follow it. http://www.gmsquarebody.com/forum/showthread.php?t=2500
Camper Special usually included things like stronger rear springs, a sway bar, camper wiring, steeper gears, etc.
Also had a tad higher GVWR if I remember too. Not sure what years, but Camper Special also had the old wood bed style in squares too. Maybe just 73 and 74.
Dieselshine
Sylvan lake
2500 trailering special
Where the camper specials the same as a trailering special??? My 79 3+3 says 3+3 then under it trailing special 12,000 gvwr, the spring pack in the rear is insane and when yea come off a curb its like not having rear suspension at all lol but on the highway drives like a caddy suprizingly enough
They were similar packages, but not the same.
Sprinter63
