Mystery sensor?
Justins83'
Beaumont
Justin
83'
I have two sensors on the block of my 83'.One's above the oil filter on the side of the block and the other one is by the starter on the other side of the block.They're a two prong hookup.Is this a low oil sensor or something?The reason i'm asking is because I have a oil leak from both of em(really bad leak on the driver side one) and can't find anything to replace em with at the parts store.
Justins83'
Beaumont
Justin
83'
I have the typical oil pressure sending unit on the intake mani by the distributor too btw guys.Gauge still doesn't work for some reason.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I'm thinking oil pressure, knock or coolant sensor.
Justins83'
Beaumont
Justin
83'
Coolant is more towards the front of the block on the driver side right under the manifold.Knock or oil pressure is what i'm leaning towards too.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Ya coolant is towards the front. Then its knock or oil pressure then. The one by the starter could be the knock sensor.
I'd bet hrpc would know for sure! We don't call him Chilton for know reason, although we may have to upgrade him to Haynes :)
Justins83'
Beaumont
Justin
83'
Alright so I did some digging and found out it is the sensor for the low oil light.Only seven bucks at the parts stores.Sweet!Don't ever deal with idiots(Not all of em are dumb,just most of em around here)at the parts stores,just look it up on their websites.lol Still don't know what the one by the starter is though.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Knock sensor. Thats where the knock sensor is on TBI.
Justins83'
Beaumont
Justin
83'
Wonder why a 83' would have it though.I thought tbi didn't start til 87',Even though some bastard child 86's got it.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
If its a 305 the sensor on the passenger side of the block by the starter is a knock sensor. Most people just phase that system out and convert their distributor over from the ignition control.
Justins83'
Beaumont
Justin
83'
I can't find a knock sensor on any parts store site when I look up my truck though.Plus knock sensors normally don't have oil flow to em.They just screw in the block a little bit and sense unusual harmonics in the motor like detonation.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
i'd personally take that as an insult. both are crappy excuses for a "repair manual"
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
the one above the oil filter on the side of the block is an oil pressure switch, the one by the starter (just in front of it, just above the oil pan rail) is a knock sensor.
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
your truck does not have a "low oil light".
your 83 would have it because starting in 1982 GM offered "Electronic Spark Control", an electronically advanced distributor. TBI didn't start until 1987, and no "bastard child 86's" got it... the bastard children occurred as 1987 trucks with carbs.
Swims350
Logan WV
none
x2 83's had the esc and up and that's what the knock sensor is for, the oil pressure switch is over the oil filter. it is used on some of the newer trucks for the fuel pump stuff, and could be the idiot light for yours and if it's the right one it works for a gauge. The one on the back by the dist, is the same way.
The one by the starter is a knock sensor. if you remove it coolant comes out. The drain plug/bolt is on the older vehicles.
I think he meant low oil pressure cuz that's what the light is, you either have a gauage or a light.
TBSS GUY
