- May 18, 2020
- Washington
- Todd
- K20
I doubt any of the things you mentioned are the cause of random stalling.
And likely not contributing causes if it generally runs fine otherwise.
Overfull oil is an issue unless it was just over filled, presuming you don’t know what the previous oil level was.
Assume it’s still a TBI engine since you asked about fuel pump relay.
As both ignition and fuel are electronically controlled the likely problem is an electrical short “somewhere “ between the ignition switch on the column and the final destination (ign module, coil, fuel pump, injectors).
Equally likely it’s a bad or intermittent ground in one of several locations.
Tough part is finding a local shop who is honest and has a mechanic that can do actual physical diagnosis without a code reader and computer.
Given your level of knowledge, I’d first check and clean every ground you can find. If that don’t work, the decision tree gets several more branches.
Although if you can pinpoint whether it’s spark or fuel that’s half the battle.
If it starts right back up, that is tougher. If it dies and won’t restart for a bit it’s much easier to check spark or fuel.
Good luck!
Good luck!
