Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
Once again, I come to dip my cup into the wealth of knowledge of the Square body community!!!
There are obviously more differences in years of these trucks than I anticipated. The latest issue is the fuel filler neck. The original filler neck had 2 tabs that bolted to the bed. This bed doesn’t have the mounting holes for the tabs.
It would really make my day if all I need is to replace the filler neck with the proper parts. Since the truck was originally diesel powered (since swapped to a 455 Olds gas engine) the gasoline nozzle doesn’t fit well. This would give me an excuse to fix that minor inconvenience.
This is the filler neck mounting tabs used on the original bed. This is a 81 GMC long bed, originally diesel powered.
This is what I’m working with. I THINK this bed came off a 77 truck. I’m not sure what I’m missing, I assume I’ll need the filler neck to match the bed? I really hope the fuel tank itself is interchangeable with what I need, the tank is only a couple years old. Hopefully someone in readerland can identify what this bed came off of, and more specifically, what I need to fix this. It would really make my day if all I need is to replace the filler neck with the proper parts. Since the truck was originally diesel powered (since swapped to a 455 Olds gas engine) the gasoline nozzle doesn’t fit well. This would give me an excuse to fix that minor inconvenience.
