Manual spring starter
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
Wasn't sure where exactly to ask this but is anyone been successful adapting a manual spring starter to a square?
Love the idea. I understand mounting and access could be difficult but it makes sense for a backup. I know bump start might be mentioned but being by yourself its hard to push a burb, especially on/in terra not-so-firma.
Turbo4whl
Downingtown, PA
Wayne
What about an air starter? Check the adapter at 34 seconds:
What the heck is a spring starter?
Jawzjeep
Washington
Joshua
Suburban
I was liking the idea of nothing needed except for muscle to make it start
@bucket I think he's talking old lawn more style wind the crank handle which winds the spring when you release the Springfield turns the motor over. Too much work just put an extra pulley on the balancer, wrap a pull rope around it, stand on the fender and let her rip.
WebMonkey
Missouri Ozarks
not used/seen one on a 'truck'.
had one on a lawn mower when i was a kid.
instead of a recoiling rope pull, you wound a lever around and around where the rope would have been.
when the mechanism 'clicked' you had it wound all the way like a watch.
then you pressed the release catch and the spring 'cranked' the motor.
'monkey
Jawzjeep
Washington
Joshua
Suburban
Industrial application usually for generators no power needed to start some ocean going vessels
Jawzjeep
Washington
Joshua
Suburban
Turbo4whl
Downingtown, PA
Wayne
You could still use muscle to start with the air starter. Small air tank, hand or foot pump and a ball valve. Fill the tank by hand and go.
Looks like you found your spring starter. Need to make the adapter for the GM engine?
Jawzjeep
Washington
Joshua
Suburban
I get your point. Not looking at air starters.
Finding the spring starter isnt too hard. There's a few makers I've seen already. I was asking if anybody has adapted one to a square. I know its a long shot but it could save me some of the legwork is all.
Even considered adapting a Coffman kind of setup for back up purposes.
Turbo4whl
Downingtown, PA
Wayne
I am liking that spring starter more than the air starter.
Add a hole in the fender, more length to the crank handle and a cable to the release. Crank it, hop in the cab, pull the cable release and go.
Did you contact the manufacture(s) to see if they offered a mount for the GM engine?
Jawzjeep
Washington
Joshua
Suburban
Found this one too and its sized for a cummins. This is brand called cqstart. $1150!
504SquareBody
