Manual locking hubs
scenic760
SoCal
Suburban K10
Hey All,
I was rebuilding the front brakes/hubs and I got some Mile Marker manual hubs while I was at it. I went to install the hubs and for some reason they do not go far enough into the hub for the lock ring to retain it into the hub housing.
It was dusk on Friday west coast time so no one to call.. I looked at several YouTube vids and instruction sheets and the only thing I can see is that the hub lip may be too thick to fit the snap ring even when fully seated in the hub housing? Or am I doing something wrong?
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Yeah, that hammer handle looks too small for the hammer you really need!
scenic760
SoCal
Suburban K10
Yeah, I should probably take a new pic before I send that too Mile Marker, haha! I swear I was merely a 3lb mallet to knock in the rear wheel seal, I SWEAR IT, haha
Loco Hills
K-30
Am I crazy or is there a broke stub axle inside the old hub?
maybe why you’re replacing huh,?
Man,I would say it’s an issue at the hub itself.These hubs have been being made for so long,it’s just clockwork.
Some people use too much grease.Directions say not to_Or something is up with your bearing lock nut and adjustable preload nut.
once the hub body is out,wouldn’t be anything else in there but the previously mention bearing nuts.Adjusted to 50 foot pounds and locked down at 80 or so?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
One thing is make sure the axle did not slip backwards. Sometimes that happens are you are installing parts. I can't recall if it was my MM or the Warn hubs, but I recall the outer retainer clip/spring being a PITA to reinstall due to clearance.
scenic760
SoCal
Suburban K10
Exactly what I was thinking too... there really isn't anything else in the way... I almost cant believe I am the only one having a problem and I'm pretty sure its operator error because as you said they should be like clockwork...unless I somehow have the wrong part
scenic760
SoCal
Suburban K10
I cant even get see a sliver of the hub housing groove to start a retainer ring..its weird because the instructions say there should be some "float" when the outer ring is installed too
Loco Hills
K-30
I’ve used mile marker and warn on Chevy 1/2,3/4,and 1 ton front axles with no problems.Warn came standard on a lot of 1 ton Chevy trucks.
Defiantly could have the wrong part,I suppose.Might re-torque your wheel bearing nut and lock nut.Make sure the little nub on the bearing preload nut matches up with the lock ring and sits flush,then outer lock nut.
Might give Mile Marker a call and check your part #.If it’s happening to you,most likely it’s happened to someone else and they may give you a resolution
scenic760
SoCal
Suburban K10
Mystery solved!
So after speaking with the folks at Mile Marker (great customer service BTW) we figured out it was a "miscast" hub. I looked at the other hub in the kit and it looked IDENTICAL (I measured the lip edge as well) to the one that didn't fit so I didn't try to drop it in...rookie mistake I guess!
I suspect it had to do with the cast portion of the hub and not the aluminum outer part which looked to be machined.
I looked at a picture side by side of the old hub and new hub for probably about 30 mins trying to figure out why it wouldn't fit...
If anyone else out there is having issues getting their hubs to fit from clearance issues, a miscast hub may very well be the culprit.
CRAIG85- I think this may have been the source of your issue too, just not as severe as mine because it sounded like your fit- although BARELY?
Loco Hills
K-30
There ya go!Glad it was something easily solved and not some kind of issue with your truck.
scenic760
SoCal
Suburban K10
There ya go! Glad it was something easily solved and not some kind of issue with your truck.
Yeah..what I thought was going to be a fix as you go rolling project turned into a redo everything before it hits the road project...it sat for a while so as I'm going through just about everything I'm finding it needs to be replaced/rebuilt...and if I do this then I should do that... mission creep...
Thanks!
scenic760
SoCal
Suburban K10
Yet another little twist...the Mile Marker guy sent me out a replacement hub via USPS and it sadi it was going to take 7 days to get here! I was like your really going to pony express me a replacement part that was defective?! So I ordered another set next day delivery through Amazon and was going to return the bad one with that..so I got the new set today and BOTH hub would not work!! I look at the splines on the hub and I think I see what they are not working and they told me it was a "casting defect"
Hey Curt, are you in Carlsbad, CA or NM?
Loco Hills
K-30
NM.Can you take pics of the brake hub inside?Pic of the front axle
scenic760
SoCal
Suburban K10
Hey Curt,
So I figured out what was happening after 3 sets of hubs and only 1 hub would install correctly. Some of the splines are not cast straight and have a slight taper to them prohibiting them from sliding in the hub all the way. I looked at one I tried to install and noticed the housing spline made a mark on the aluminum where it was getting held up and I took a Dremel and ground the taper off and it slid right in...
Loco Hills
K-30
Man,I bet that was frustrating.But you got it!Thats awesome.
Hopefully no more surprises
Mistafishe
