Make Your Truck Bed More Organized and Convenient to Use with the AeroBox
carid
Preferred Vendor
Preferred Vendor
usa
carid
4.6 L
Introducing the AeroBox, extremely useful and convenient storage solution for your truck bed. The accessory makes the traditional toolbox obsolete by offering quick access to your valuables from the back of your truck and the ability to remove the box completely in seconds to be rolled away on integrated rollers. Its durable, lightweight, seamless construction is molded from black polyethylene using a rotational method and has a grained texture.
The Standard version of the accessory is designed to be mounted on the bed floor. The Premium package includes side panel mounts allowing for quick release and more secure installation, exterior tie-down rings for securing cargo inside the bed, and interior divider panels for organizing your valuables. The box sits below the bed rails, which means that you can use any tonneau cover or camper shell without any problems.
AeroBox® ABSA02 - Standard Single Drop Door Rear Mounted Truck Bed Cargo Box
AeroBox® ABUA02 - Premium Single Drop Door Rear Mounted Truck Bed Cargo Box
Specifications:
Box Width: 58.5" (which is also the minimal tailgate opening)
Depth: 19"
Height: 19
Weight: 50 lbs.
Standard Features:
Integrated compartments for small items in the door
Door can be removed and used as a portable work surface
Seamless rotational molding construction
Recessed features on the top and back walls for securing long cargo in the bed
1/4 turn universal floor mount fasteners make securing your box to the truck an easy task
Decreases drag caused by the tailgate
Works with most tonneau covers and camper shells
Uses premium locks and existing tailgate security
Easily to remove and roll to a new location
Locks into place easily in a truck bed
Black grained texture
Made in the USA
+Premium Features:
Side panel mounts
Interior divider panels
Exterior tie down rings
If you have any questions, feel free to ask them here, in a personal message, or contact our sales team at 800.505.3274 (toll free)
DucatiDave
