Lubing warn hubs?
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
What does everyone do? Last part to reinstall on my front end.
Read some stuff online about 90w gear oil, others said nothing, some said bearing grease.
Does it matter?
Sent from my SCH-I605 using Tapatalk
marks86
Latham, NY
Mark
12v Cummins
I always use a good bearing grease
flyboy1100
UsA
me
k1500
Just a light coating?
MadOgre
NA
NA
NA
NA
NA
Don't use gear oil or penetrating lube as that stuff will not stay and penetrating oil will break down your wheel bearing grease.
Like Mark says a light coating of clean wheel bearing grease. Trick is to clean them hubs good before recoating with wheel grease. The grease will stay and prevent the plastic parts from wearing. Also a light coating of grease on the rubber seal too.
flyboy1100
UsA
me
k1500
Ok :)
flyboy1100
UsA
me
k1500
Well, the ones i have aren't warn, not sure what brand they are. They are sticky and i can't seem to get them better, so i picked up a set of warn standards today. They do have a little grease on the gears, not much though. The move much better
chengny
They do have a little grease on the gears, not much though. They move much better
Leave them like that.
Unless you intend to submerge the axle, any more grease than what came from the axle is overkill. Excess grease can cause a hydraulic lock situation and prevent the gears from moving in and out.
A lot of people don't use any grease at all. They just dip the sliding components in 90W gear oil prior to assembly and that's it. Personally, I use a light (brushed on) coat of nickel never-seize and loosen that up with a quick spray of WD-40.
Be aware that, the only time these parts move against each other is when you are actually locking/unlocking the hubs.
flyboy1100
UsA
me
k1500
In hoping to never really have to look at these again for a long time. Time to go install
adhkjashda
