Low oil pressure in a new motor?
74 Shortbed
I always thought AutoGage was their budget line. ???
The Autogage is just a plain jane guage nothing fancy so it is cheaper but that's it, the gauge and senders are the same quality as any other style.
87scotty
Central il
Andrew
V20
5.7 for now
im just happy when a vehical has oil pressure generaly if she spins a rod or main she was tired anyhow
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
BigPoser -- What weight oil are you running? If it's 10W-30 try 10W-40. That will probably keep the hot idle pressure above 10 PSI, while keeping the viscosity low for good oil flow on cold startup.
Running 10W-30. When I'm cruising 60 down the road I'm hovering around 35psi. I do have a 700R4, but don't know my gearing though. I'll have to check out my RPM's when going 60, but I know it's not that high. Falls inline with 7-10psi per 1000 RPM though.
MikeB
North Texas
I'd suggest 10w-40 at the next oil change. And if your engine doesn't have a roller cam, then use a good oil with high levels of ZDDP, like Driven HR 10w-40. Not cheap oil, but cheap insurance.
sparky77
