Looking for insight on a cummins swap
HEG77k10
Adna, Washington
Hayden
Chevy k10
400 stroker
Howdy, I’ve got a 91 burb with a half ton frame and 3/4 tons runnin gear (dana44 and Corp 14 bolt). The beast has a 9 inch lift in front and 11 inch in rear. It had a junk 350, last owner used rtv as a head gasket :/ ,,nuff said.bullet proofed the th400 and bullet proofed the np208c. It originally was gonna get a 400 stroker but that went in a different project. I want to find a 12 valve to put in, and a nv2500 tranny. What do I need to know before I get too serious? I’ve heard that you need to get a plate to “clock” the transfer case so the front driveline is lower. Will a np208c work with a nv2500? Any info is greatly appreciated. Thanks
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You will need to move up to a D60 up front. The Cummins will be too much for ten bolt housing... forget about the wimpy axles and knuckles..
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Np208 bolts right up to an nv4500. Not so sure about the clearance though with a Cummins swap. You’ll need to get figure out the shaft in the tranny to input from a Cummins and output to a GM 208.
tweeter68
