MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
At it's most basic, the only thing the TCC system requires to lock up the power train is 12VDC to the solenoid.
The solenoid is internally grounded through the transmission casing. So, if the coil is good and you supply a hot wire to it, the valve will operate.
I have looked at a lot of wiring diagrams over the past couple of days and, while there are many variations of the wiring harness into the transmission, one thing is consistent. The lead that supplies power to the TCC solenoid is always light green.
Take 12 volts from anywhere, run it through a switch and feed the solenoid coil (via the light green wire). When you want overdrive, flip the switch closed and the torque converter will lock up.
Thanks guys I really appreciate all this help. Will keep you guys posted on this.
