LMC Rear view mirror
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I have a black 10" LMC Day Night rear view mirror that came with my Suburban and I mounted and adjusted once. Then pulled it down and installed a late model GM temp/compass mirror. I would stop short of calling it new, but it pretty much is.
LMC part number is 38-5120
Asking $15.00 shipped to the lower 48.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Stopping short, eh?
In all seriousness, I don’t need this as an emergency, but if no one bites, I could use it.
SDJunkMan
Black Hills of South Dakota
Jeff
I installed a late model GM temp/compass mirror.
Not trying to sidetrack your post but I have thought about adding a factory temp/compass mirror. Hoped to find one at the pick a part, but was wondering where the temp sensor is mounted and if there is anything else needed (other than power) to make one work.
Crispy
Suburban V1500
No worries. The temp sensor is mounted behind the grille to the radiator support or somewhere along those lines. Best bet is to find the sensor in a junkyard so you can get the weatherproof connector as well.
I used the following parts:
GNTX-177 mirror from a 95-02 GM truck, with the harness. This has temp and compass, but no onstar. Models vary with a single line or double line display.
GM ambient air temp sensor with harness. Part number for the sensor is 15035786. I bought it used with the harness as mentioned above so I dont have the part number for the plug.
The harness for the mirror came with 3 wires so I needed to add 2 wires to complete the circuit for the temp sensor. The diagrams are available online and are very simple. The mirror contains the compass and only needs power and ground. The sensor is a 2 wire hookup directly to the mirror.
Highly suggested mod. I didnt take pics during the install but I plan to snap some and do a write up when the weather clears up again. If you have any more questions just let me know.
SDJunkMan
Jeff
Thanks for the info. I'll have to see what I can find at the pick-a-part. I figured that it was probably behind the grill, but having the part number helps.
Crispy
Suburban V1500
No problem. Let me know if you dont find one. I have that Tahoe i'm pulling the engine from and I believe its the same sensor. The mirror is a temp/compass mirror but it has onstar.
SDJunkMan
Jeff
Will do. Going to try to get to the pick a part this week.
Wracks81
TN
c10 scottsdale
Interested. Any pics?
Crispy
Suburban V1500
See below.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Stopping short, eh?
Poor fusilli Jerry lol
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
“He had to use corkscrew pasta...”
That’s what fusilli is.... or am I misinterpreting your sarcasm? I know your a bit new to the concept and I’m here to help......... lol
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
No, that’s what Jerry said when they were sitting in the proctologist’s office, and then Jerry, George, and Elaine scooted up in their chairs. Skip to 3:12.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok I’ve seen I just didn’t remember the whole schtick.
Wracks81
TN
c10 scottsdale
Pm'd you
87R10_Cruising
