lift help!
mr79k25
Virginia
Robert
k25
I bought a 79 k25 that has a set of 40x17/16.5 ground hawgs. I have no idea what size spring lift it has. It has a 3" body lift and a approximately 4" lift block in the rear. Otherwise its all spring. The wheels are 10" wide and tires rub the fenders. I'm thinking its a 6" spring. Where could I get a set of springs only? The front spring is bent causing the collector to hit the spring hanger. I'm looking at doing a shackle flip and throwing away the block.
Show us a pic of the truck from the side.
mr79k25
Virginia
Robert
k25
bigcountryguy19
Sealy texas
josh
6.2 diesel
I would say someone put on a 4" lift kit that came with front lift springs and blocks for the rear then added the body lift, might have to go with a six inch all spring lift combined with the body lift to clear your tires, or do some fender trimming
Driver4r
Nebraska
Trevor
k10,c20
mr79k25
Virginia
Robert
k25
Wish I could figure out how to turn it! Lol. With the law requirements I'm not wanting to replace the springs with a 6" set and be over the legal limit! Wish I knew what size kit was on it!
87ChevyR10
Kansas
NA
NA
NA
Fixed
mr79k25
Virginia
Robert
k25
Thanks! After looking at the super lift web site its gota be at least a 6" spring kit. No way would 40's clear with a 4" suspension and 3" body!
bigcountryguy19
Sealy texas
josh
6.2 diesel
Then why would it have 4'' lift blocks in the rear? You had said the tires don't clear and rub I thought?
Driver4r
Nebraska
Trevor
k10,c20
it will be a rough number, but you could run a peice of string from the bolt holding the spring to the frame, then the other end to the bolt on the shackle(both on front spring) then measure down to the top of the spring. And how many leafs are in the pack?
mr79k25
Virginia
Robert
k25
Here's what I could take this am.
bigcountryguy19
Sealy texas
josh
6.2 diesel
Those are stock rear springs. So it most likely has a 4" suspension lift. Along withe the 3" body
mr79k25
Virginia
Robert
k25
Would it be possible to run a set of 40" tires with 7" lift and almost no rub?
bigcountryguy19
Sealy texas
josh
6.2 diesel
35" tires usually fit a 4" lift with no rubbing as long as they are not super wide. IMO the 7" you have should fit the tires you have, from centerline of wheel, ur tires are only 2.5" taller than 35" tires. So the body lift is compensating for the extra tire size.
mr79k25
Virginia
Robert
k25
I'm running 40x17/16.5 tires on 10x16.5 wheels. Would anyone have the measurements of a 3/4 with 6" suspension lift and 40" tires? I'm looking to get a rough idea of how high the bumpers are from the road. I believe I can't exceed 28"
andrewlcraft
