Lift blocks
lee0123567
Ottawa, OH
Lee
ZZ4 350
I need to raise the front end of my truck up 2" so it sits level. How many lift blocks would i need and would i need to mod anything else to make it work?
8T6K5
AZ
L98 350 TPI
Never use blocks up front.
Sent from my iPad using Tapatalk
Right, NEVER use lift blocks in the front and don't ever double up blocks in the rear.
lee0123567
Ottawa, OH
Lee
ZZ4 350
So do those metal "not spring" come in different sizes or do you just put multiple ones together?
No, just use one of them. If you need more lift, it's time for new springs.
8T6K5
AZ
L98 350 TPI
^^ is there a specific reason you want 2"....old ones sagging?
lee0123567
Ottawa, OH
Lee
ZZ4 350
The ass end is 2" higher than the front end. The truck looks like it's 2wd right now. I just want to level it out if there is any other way to do it.
8T6K5
AZ
L98 350 TPI
lee0123567
Ottawa, OH
Lee
ZZ4 350
Here's what the front leaves look like.. opinions?
lee0123567
Ottawa, OH
Lee
ZZ4 350
Mmkay, where can i get a good set of cheap ones?
8T6K5
AZ
L98 350 TPI
Im not sure what you budget is, but you can start on Summit or Four Wheel Parts....
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
hell just get a set of add a leafs itll level it up and not make the ride much harsher.
8T6K5
AZ
L98 350 TPI
True, my thought was if the springs are toast all the bushings may be as well, inspect those too.
If so, it may be easier to do the springs.
beetlejuice01
