- Mar 5, 2014
- Kansas City, Missouri
- ryan
- r10
while doing my rebuild I am going to need to redo the cooling system and it starts with replacing the cracked out 29 year old factory radiator. I am assuming this because I have no records of it being changed and it looks factory.
Anyways I was searching around and found out an aluminum core is the way to go. Along with the diameter of the tubes is important. More contact to help cool the coolant and I've read 2 row with 1" to 1.25" tubes are more effecient than 3 and 4 rows. Due to the fact the air flow flows better and doesn't get disrupted like in the 3 and 4 row radiators. Other flaws of the 3 and 4 rows is the tube size. They're smaller so less contact. Seen that a 3 row had tube size .63, that's 1.89" of surface area where as the 2 row has 2".
what is everyone using to replace the stock radiator? I know I could go down to oreillys and get a Murray one but I do not like the looks of a plastic case with aluminum core. I want an all aluminum radiator to give it a nice look in the engine bay. Plus I would like to convert over to an electric fan as well while I am at it.
All I can find are ones for 28x17 core which I have a 28 1/4x 19 core. Any suggestions are much appreciated.
