Legs TOO short. Need side steps
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Dammit, why can everyone else find these manual transmission K20s??? :shrug:
I expect I'll be having a problem getting in mine due to back problems. My intent is build some type of rock sliders and have them double as a step.
Those single steps just scare me as something that will get snagged while out wheeling and get ripped out of the sheetmetal or damage the rocker. :shrug:
If you just bolted them in with the sheet metal screws they come with I think they would rip the screws out of the sheetmetal before ripping big chunks out of the inner rockers. Now if you welded I’m not sure, the brackets could probably rip off before the rockers honestly
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
I had this step mounted on driver's side only. The gas tank on passenger side
didn't provide the clearance I wanted, plus let the passenger climb in. ;-)
I really didn't care for the step, so I removed it and cobbled together these side bars from stuff I
had saved over the years. They're bolted to the rocker and the frame.
DaleP
Wrangell, Alaska
Dale
Nice looking rig. What didn't you like about the step?
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
Thanks for the compliment.
Mostly it was mounted too far forward and made using it awkward.
If you go that route, be sure it's where you want it before you start drilling holes in the rocker.
I felt about middle of the door would have been better.
Here's a pic that shows it better...
PrairieDrifter
North Dakota
Mason
Yeah for sure, those style hoop steps should be almost in the middle of the door. I like mine a lot personally. I think the directions said to mount them at the front edge of the seat
89 burbarian
ontario canada
chuck
suburban sle 2500 2wd
454 tbi
hello, my question is can my perfect rockers handle 300 pounds daily on those small ones also not wanting to drill holes can they be mounted differently do they even come out far enough for a big guy
PrairieDrifter
North Dakota
Mason
I think there should be plenty of room to get anybody’s foot on there. I think welding the brackets on would be your best bet but that would mean you would have to take some paint off and throw some paint on after you’re done.
Personally I think the rockers and the steps would handle it. They do tuck up a little bit, these pictures are where the step is almost perfectly level, they have a slight inwards lean towards the center of the vehicle. But you could bring them down some, it just means you only have a few adjustment spots before the angle of the step gets way too far from level.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Inner rockers on these trucks are pretty thick. They will handle the weight.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I’d be worried about them holding my fat butt. I can’t see them being all that sturdy.
idahovette
Weiser Idaho
Perry
K20-K10
They work!! I put a set on a customer's 88 K1500, jumped on em hard. They stayed put . He was worried he goes 250 lbs . I am 215 and I didn't have to get up off the ground when I lit on them, so they are fine
Tcminer
Idaho
Those single steps just scare me as something that will get snagged while out wheeling and get ripped out of the sheetmetal or damage the rocker. :shrug: Just built these this week. Will not fit with side saddle tanks. I put a 25 gallon blazer tank in rear between the rails.
Doppleganger
OH-MI: Just like it sounds
You cant come on here, make one (your first yet!) post of teaser pics and not show us the rest of that truck. Its in the rules....somewhere.
I know it is.
michaelmarine53
