LED headlight upgrades
Bigbodylexus
Wichita, Kansas
Kendrell
R1500
5.7L V8
I purchased 4 of these sealed beam conversion kits with LED DRL's. My problem is, even though they are 4" x 6", they do not fit the factory opening for the quad headlights on a 1990 Chevy Suburban. Any suggestions?
ThisOldK10
Nevada
R1500 Suburban
5.7L 350
The quad headlights on suburbans are a strange size. They are like 3.5inches by 5 inches and there is a specific bulb number for them:
Low beam: H4703
High beam: H4701
I believe those are the numbers, if you search and make sure that the lights are for the quad headlight suburban you should be good.
83sbc
Houston
C1500
I’m having the same problem I’m doing a 89front end conversion to my 83 gmc c1500 and am looking for led housings so I can change bulbs instead of changing a whole halogens ind I can’t find any I found the originals which are the ones that @ThisOldK10 mentions but The dimensions are 92x150 mm let me know if it helps and if u find any plz let me know
Taco main chew
