Lean MISFIRE! need help.???????
whitelightnin13
fort campbell
eric
idles normally, but taking off too fast or climbing long inclines (worse from a dead stop). I have to feather the pedal to keep it from missing. first the motor stumbles then the misfire(s). My carb knowedge is probably a 4 out of 10. any input would help.
***Found vacuum line off distributer that was unserviceable. Replaced and no change in driving.
MadOgre
NA
NA
NA
NA
NA
You need to do a carb overhaul and buy new floats. Make sure they are adjusted properly.
350runner
tx
Ceasar
Check for spark plug wires touching metal. That will give the same symptom. If they short to ground( metal) it will cause a misfire.
MadOgre
NA
NA
NA
NA
NA
LOL I said floats! Ahhh. Its been too long with out my trusty Q-jet!
Quadrajet Power
Waring, Tx
Mark
K5 Blazer
What carb do you have?
If it is a quadrajet you need to check the secondary air valves to see if they are opening too fast. Could be the primary air break is not working or tension spring is loose or broken.
MadOgre
NA
NA
NA
NA
NA
At any rate a full rebuild is in order
whitelightnin13
fort campbell
eric
edlebrock 1405 , yes the rebuild kit will be ordered soon because its cheap. how can I prevent the card from needing another rebuild when I got to korea for a year?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I'm fighting the same situation with mine. Timed vac advance instead of full, longest throw on the accelerator pump arm, and some timing tweaking seems to be calming mine down but I'm beginning to wonder if I need a timing chain, seems my timing is all over the place. Have you put a vacuum gauge on it yet? That might help you figure out if the intake or carb gaskets might have a leak.
rich weyand
Bloomington Indiana
Rich
If by "longest throw" on the accelerator pump arm, you mean the hole in the end of the lever, that is actually the shortest "throw". The longest throw is on the inner hole.
You might know that. Just making sure, because I have seen people get that backward.
crazy4offroad
K-10
350/SM465/NP205
Yeah the one at the end of the rod is the shortest. I've fought mine ever since changing to vortec heads.
Snips71
