- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
I "gooped" it.So what did you actually end up doing to fix it other than taking it off and redoing the gasket? We need commentary![]()
I've seen ALOT worse, not bad for a 20 year old engine.
The back lower corner was leaking almost as bad as that blown oil diverter gasket, and this hi-perfomanc gasket is brand new, so the valve cover is beat. SO I just cleaned it up and slapped some goop on it for now, I dumped enough money into this thing this wnter....Cool, and those are the better more expensive gaskets too. Doesn't look like you have a bad problem with valve covers leaking though, unless it was in the back of the front. Looks kinda dry by the exhaust manifold unless it was slow enough it burned it off. My 454 is leaking at the valve covers a bit and when I shut it off, its burning off the exhaust manifolds.
Don't mean to be the bitch here, but you know how I am by now. Looks to me by the pic of that head, someone has neglected that motor of oil changes or used some junky oil. Was that you or the PO? Just blame it on the PO wouldja??? I don't wanna hear it was you.
