K5 Diesel to Vac booster pedal spring?
Tja1161
Southern California
Tom
GMC JIMMY K5, 1985 K2500
I converted my K5 6.2 to a gas engine and swap in a power booster set up. I had to buy a diesel pedal and assumed the spring originally had to go on the power brake pedal. I have a lot of travel with spring on and am wondering if I need the spring? Thanks in advance for the help
RoryH19
Rory
R10 Silverado SWB
If I recall, diesels come with hydroboost not vacuum assist. Did you convert the hydroboost when you swapped the engine? Brake pedal setup will be different between gas and diesel too. I have a gas powered k5 if you need a pic.
Craig 85
Nashville, TN
454/TH-400/NP205
To add to RoryH19's comment, I believe the hole for the push rod on the brake pedal shaft is in a different location than the hydro-boost. I recall seeing a thread on here a while back when someone converted from vacuum to hydro.
Tja1161
Southern California
Tom
Sorry if my post was confusing. Yes, the pedals are different. My K5 was originally a diesel with hydro-boost. I bought a gas brake pedal from a member here when I converted to vac assist.
My question is do the gas trucks have a brake pedal spring like the diesel? I only see a spring in the manual for JB8 diesel brakes. I put the spring on but I am wondering if I needed it as the brake pedal travel is huge before the brakes engage.
Thanks
I believe the spring is only for the hydroboost pedal. I don't recall a spring on any of my vacuum brake pedals.
Tja1161
Southern California
Tom
Thanks. Maybe i will take it off and see what it does. However, I seem to recall it was pain to install. Thanks
custodian
Catawba
William
5.3 LS, 350
I too changed from hydroboost to vacuum boost. I haven't changed my brake pedal yet. There is a difference. I took pics of the pedal on my 73 and compared it to my 85.
The picture on the left is from the 73, it originally had manual brakes that I converted to power brakes, the picture on the right is from the 85, that is originally hydroboost. See the difference where the push rod mounts?
custodian
Catawba
William
5.3 LS, 350
Could you post a pic of your setup? I too switched from hydroboost to vacuum boost and looking for the right brake pedal.
custodian
Catawba
William
5.3 LS, 350
I looked at that thread. So the only real difference is where the push rod and the brake light/cruise control switch bracket mounts?
What I'm seeing is that the hydroboost pedal would push the power booster push rod further than needed? I'm I correct on this?
I bought one from a C30 with power brakes and AT today. Going to take the hydroboost pedal out and compare them.
C30vet
