is this normal?
Croc1990
Saskatchewan, canada
Dakota
Doing the intake gaskets and noticed the distributor cap. Do you replace the coil on top too? I'm assuming its wore out
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I've had disintegrated ignition parts like this before. You have to replace the cap, of course, and there's an coil insulator and distributor bushing that sits under the coil/goes through the cap. If those are visibly damaged, you need to replace them. If you're getting a healthy white spark, your coil is doing its job. Here's a test, though.
If it was still able to run like that, the coil must still be plenty strong.
gpmorgan
Tupelo Ms.
greg
Yeah, you should need the cap and rotor only. I think the cap will come with the carbon plunger, spring, and insulator that goes between the coil and cap.
75Monza
Colville, Washington
K30, K20, K20
That's pretty standard on my rigs...always took it to mean I have a strong coil and bought a cheap cap. With higher rpms on a long trip, still haven't been able to prevent that from happening until I went to off cap coil for HEI.
I've never had a cap do that. I never run the cheapo ones though.
Croc1990
Dakota
I just grabbed a champion one from Canadian tire.
While I got you guys on here I'm kinda torn about the intake gaskets. I know to use rtv on the China wall but do I put the gaskets on dry? I've read too many conflicting things.
Thanks
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thanks
I Indian head them but that’s me copper hightack works too but I like my Indian head the next guy that’s gotta take it apart won’t though lol
If the coolant ports have any pitting at all, I smear a very very thin coating of RTV around them. I like to use nice embossed gaskets. Cheap flat gaskets should definitely get a dose of Indian Head.
Croc1990
Dakota
Never heard of Indian head I'll have to find some. So black rtv on China wall, blue around water ports?, and spray Indian head on gasket lay it on there
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Indian head is a gasket shellac it comes in a bottle with an application pom.
I do not believe in blue rtv. I use Ultra Black on just about everything. Not to be confused with regular black.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I never heard if it be referenced as the China wall. Me likes. I used the Mahle head gasket set last time and it came with rubber gaskets for the china wall which I thought was pretty cool. I ran a thin bead of ultra black along the mating surface to ensure the gaskets didnt move. I also dabbed a little on the lower ears of the intake manifold port gaskets so they wouldnt move either. Seems to have worked.
Many people including myself like to skip the rubber end gaskets and run a 1/4 inch bead of rtv instead. The rubber gaskets can push out.
  • Like
Reactions: WFO
Steveo75
