Is this cab worth trying to save?!
adaml23
Decatur, IN
Adam
Scottsdale
Is this cab able to be saved? I'd like to keep as much of the truck as possible as it was my dads first and only new vehicle even if that means some extra work but if it is going to be unsafe and or nearly impossible to bring it back to decent shape, then I'm willing to swap or get new parts.
Fyi, I will be starting a build thread soon to keep everything up to date for me and the build.
So what do you think?
[/URL][/IMG]
firebane
Calgary, AB
Curtis
I would say no. But others may yes. To save it will be a LOT of time and money.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
it all depends on the amount of time, fabrication, and money you want to spend fixing the cab. If i had a cab with that much rot i would look for another cab but that is my opinion others may say yes
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I think sentimental value is more important than money. It will take quite a bit of time it's not insanely expensive you can buy floor pans, rocker panels, and cab corners. The door pillars you could find a donor to cut the spots that need to be replaced then weld it in place.
I'm gonna frame off restore my grandpas 79k10, to me all of the memories as a little kid driving to the farm and all the work we did in that old chevy is way more Important than money, but that's just me.
Boonie
El Dorado, KS
Brent
I agree with reaper about the sentimentality. Im torn rebuilding my grandpas 74, repair the bed or replace with another one. easier to replace, but the memories of feeding cattle with him, of my brother falling over the side and hanging by a foot.......those are all in that truck. leaning towards the extra work and restoring the bed, rewelding the broke welds, and just replacing only the places that are rusted out. just my opinion
If it was mine I'd save it :shrug:
If you have the ability to take on minor fabrication, by all means, fix it. A different cab basically means it's a different truck.
adaml23
Decatur, IN
Adam
Scottsdale
How hard is it to remove a cab? I know there's the mounts that hold it to the frame but what about the wire harness? What we're thinking about doing is getting another cab and putting it on while the other one is of and getting repaired gradually and at our own pace. If we did it this way can you weld the patch panels on it with it not on the truck or would it not fit correctly when reinstalled on the original frame? We're just gathering info and ideas right now
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
I still have my first truck it is a 63 chevy that started life as a c10 long bed it is now a k10 short bed. I bring this truck up because the cab is the only part of my original truck that I have left. and it is rusted in many areas. and any sain person would not try to save it.
but I have a certain set of skills that I have acquired over many years and many truck builds that give me the experience and know how to save it.
I have to change the complete roof and most of the floor to save my cab.
it has sentimental value to me as my first truck I got it when I was 15 from my brother who got it from my best friend. I have owned it for 23 years.
but as for your truck unless you have experience and know how I would not try to save that cab.
if you do not get everything lined up right you will end up with a pile of crap
PrairieDrifter
North Dakota
Mason
I wouldn't repair everything with the cab off the frame unless you support it in every way it can move by tacking on support pieces to hold it square, and yeah if you replace the cab its not the same pickup anymore new vin, new cab, new title.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
As I type this I can guarantee somewhere in Arizona there is a cherry rust free cab going over a scale at some scrap yard.
maryland
Ricky
r10
If you can weld save it ! The metal is cheap new floor pans and corners are nothing. Good those problem are normal in these trucks. I put new floor pans and rockers in mine cost me about 100 bucks
adaml23
Decatur, IN
Adam
Scottsdale
Well we're thinking were gonna give it a shot as far as trying to save it. Too many memories for us to not at least attempt it. Worst case, it comes out destroyed and we're out some money but we'll have made a few last memories in it trying to save it. :)
And FYI, we actually just traded another vehicle for a donor truck that we can harvest pieces of the roof if we need to. Unfortunately, the floor/rockers/etc. isn't the greatest so that's out of the question although we will need to steal the tunnel as my dad's does have some rust where it bolts down to the passenger side floor.
I know there are plenty of places out there that sell patch panels but what are some suggestions for the better quality brands?
adaml23
Decatur, IN
Adam
Scottsdale
Here's a picture of the parts truck... and yes, I'm well aware that it's in better shape than my dad's truck. Luckily we just traded it for a dead ford ranger that was destined for the scrapyard itself.
PrairieDrifter
North Dakota
Mason
Lmc has good stuff a little bit pricey but the patch panels they make aren't THAT expensive.
johnalen76
