Is.... this a cylinder... sleeve? Do guys run them?
I found a box of 4 of these in my shed. I cant tell for certain but that looks like a piston to me, with a sleeve around it. I thought it was for a 250 but the box only had 4, with no others to be seen. So Im thinking one bay of cylinders in a sb? Is there a way to know?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Either that wheel and tire is really small, the sleeve is really big, or the camera angle is giving me the wrong impression.
The ridges on the outside of the sleeve make me think it's not a repair sleeve. They're usually smooth.
What's the bore diameter, and what does the piston crown look like?
The wheel and tire is a couple feet lower, perspective photo. its i think a wheel from a square. Maybe. 15 inch, 5 bolt. stack of 4.
The crown? Like flip it over? I can measure and stuff, yeah.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Yes, the top of the piston may tell us something.
Keith Seymore
Motor City
Keith Seymore
4.3L
Could be for anything.
Farmall tractrors have replacement sleeves; you can pound the original out of the block and slip a replacement sleeve in. Those would be four cylinder engines (hence the quantity of four).
K
Well shoot.. there are only 5 inline 4 tractors on the property,.. one of them a farmall.. which was parked in the field because the engine had about no compression.. and 1 john deer, 2 case, 2 massey harris. Hmm. ill try to find a number, those old tractors likely shared that feature?
ozark plateau
dennis
k5
K
dont grab the sleeve with your fingers after its been in the freezer for hours! it sticks, and takes skin with it!
MrMarty51
Eastern Montana
Martin
Top of the piston should have numbers and or letters stamped on it, use those numbers, do a search on the innernet and it should yield some infuhrmayshun. :Caffeine:
I once did rebuild a Farmall M, replaced the sleeves and pistons but I do not remember what they looked like.
Galane
Idaho
Gregg
Sierra 3500
If they are for the Farmall, quick-ish way to get it running again with new sleeves, pistons and rings. Practically a new engine.
80BrownK10
Greenwood, SC
Nate
Did t you say you have a classic Ford N tractor around? My guess is that it's for that motor. Tractors have sleeved engines many times...I personally can't say for certain if the N tractors were sleeved but I would think they were?
I dont have a ford N tractor, but I learned stick on one! I have a 1920s Fordson, but it is inline 3
aaron06
