is the 700R4 ok with a 454?
Grumpy Grizzly
Kalispell, MT
Josh
Suburban 1500
going to swap out to a 454 on my 1990 1/2 ton suburban with a mild performance upgrade rebuild and just wandering if the 700R4 will be able to handle the power
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Better have one built, and I mean built. I had a Monster Transmissions stage 2 HD 700R4 in my 86 K30 CUCV. It had the heaviest duty internal components available for the 700R4. I plowed snow with it and never had a problem. It's your choice, Monster, Mad Dog, they are all pretty much all the same. If you aren't familiar with this transmission, have someone adjust the throttle valve cable. If it's not adjusted properly you can smoke that transmission within a few miles.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Few miles. Lol
Try 5 min.
I had to learn the HARD way.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Few miles. Lol
Try 5 min.
Just wanted to warn you. Some people think it's a kick down cable that doesn't need adjustment. You could go with a 4L80 if you want to mess with a stand alone computer and get some geek to make it work. That's an expensive endeavor though.
Vbb199
Salisbury NC
Vince
I do know how the 700r4 TV cable works, that's what I'm saying :rofl:
I've burned up two 700r4's not setting the TV correctly
Edit: you were addressing the other guy, my bad.
With a 700 you have to throw every available high performance part at it with a rebuild, along with a big trans cooler. And a temp gauge so you know when to back off.
SquareRoot
Smoke it!
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If the trans works ok now, put a shift kit in, corvette servo, and roll the dice. When it needs overhauled, use a wide band, Raybestos ZPac 3-4 clutch kit, Sonnax smart shell, and find someone who knows what they are doing to build it.
Or, bit the bullet and install a 4L80
C30vet
