Irish's pickup from hell, the 454SS.
Rollin_Thunder
Oklahoma City, OK
Robert
Don't do it, keep those rockers. I have that kind on my 400 and they are awesome. Why not just try and find tall valve covers that resemble something that would be factory.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
This is a hard decision, I just looked through everything summit and jegs had to offer and cant seem to find a happy medium here. The one set I could probably live with is over 300 bucks and does not have an oil fill hole, that drives me crazy.
These are some sweet rockers, I think lighter valvetrain components are a good idea in any engine but I dont know if its worth losing the almost factory appearance for something with such small benefits. This will by no means be a rev happy engine with its crappy heads and stock tbi so stamped steel roller tips might do just as good as these bad ass aluminum ones and I get to keep the factory valve covers.
What really needs to be offered is a tall version of these: http://www.summitracing.com/parts/nal-12495488
That would solve everything. Well I already have these rockers, its starting to get kinda chilly outside so I should probably just order some aftermarket valve covers and get this thing in the truck before I am doing it in a mother ******' snow storm.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Yeah I guess you don't have a choice since cast aluminum would break. I've seen plenty of small block OE metal tin valve covers with 8 divets in each valve cover, where the idiot had to big of a cam and the rockers hit the valve covers. Talk about noisy.
Whut? You mean I can't run a .510 lift cam in a small block with stock valve covers? Duhhh !!! Honestly I don't even know for sure now but I think in a SBC, .465 is max for OE valve covers. not sure on BBC.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Just stick 1.7 roller rockers on the valves.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Tyger13us
BFE,Ut
Jeff
450hp/357cid
I was going to say? ya can use fine thread 7/16 regular nuts and just double nut them,, adjust the lower nut as usual,, then when there adjusted,, just run another nut on top for a lock nut and its just barly over the top of the rocker,, well a wee bit more,, but then ya can run stock covers......
that was in my day when we didnt like the polly locks and they were 20 bucks a pop............ they were junk back then they always came loose,, with stock nuts,, ya couldnt get i socket on um with them type of rockers....
but it looks like ya got it fingered out,,,, yea oval port heads aint the best? ya need a good set of iron squareport heads.... and if ya got money to waist? hahahahahaha a set of ls7 aluminum heads will rock your world and bank,, but aint nothing like 435+ hp 427/454 BB chiviy.......:driver:
the ball rockers on BB chivy usually bust out the bottoms of the rockers.. rollers are the way to go,, now just dont twist it up to high and ya dont break valve springs... BBC's? ether its rockers or valve springs that will let go first,, usually.....
im an old Vette mechanic.......to many years to count..........
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I will be getting better heads in the future, when the rest of the truck is in better shape. I was looking at some Brodix cast iron heads with barts valves, at that point roller rockers and fabricated aluminum valve covers will make more sense.
J Knight
Baytown TX
82 Chevy
350ci
That motor lookin purty guud Iman:waytogo:
J Knight
Baytown TX
82 Chevy
350ci
$200?
guillermoariast
