Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
yea the directions on those restrictor plates tell you what ones get blocked on what motor.
basically if one or both are open it helps in cold weather to arm up the air fuel charge, and carb, but in hot conditions of course it's bad, and neither or only one gets left open like.
I never had water leaks that I know of other then the t-stat but maybe they were seepage from the bolts? I know for sure I've ad oil seepage though on the 4 middle bolts usually.
