Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
Today is the beginning of the little build thread of how I'm replacing my Autometer fuel pressure gauge. This gauge is a "Sport Comp" series gauge just like the one that's in my dash I put in when I rebuilt my truck. For some reason it failed but it went through hell in the 25 years since it's been in my dash anyway. During the Summer months it was not steady at all. Sometimes it would fluctuate from 3 to 5 lbs, to sometimes 12 lbs. swinging wildly back and forth. Then it would steady out but would still be waving around wildly from 5 lbs. to 8 or 9 lbs.
Then during the Winter months it would be a srteady as a rock and would not swing between pounds hardly at all. Some of it's wild swinging could be blamed on engine compartment heat or something and then when it was cold I don't know why it would run more steady than not. There was not so much slack and vibration in the hose that it caused the wild swinging except in part of the hose coming from the fuel splitter on the manifold, that could be some of the cause of wild fluctuations just from engine vibration, but I don't believe it could have caused that much. My engine is balanced within a gram so I don't know where fluctuations like what I saw in the fuel pressure gauge could have come from. Here's the first thing to do is drain the hose from the gauge in the dash that goes to the back of the isolator in the engine compartment so as not to get a bunch of antifreeze on the back of the instrument cluster, and the floor inside the cab. So remove the connection first in the engine compartment so it's easier to clean up with water and soap later.
First I had to break the union fitting from the gauge hose that goes to the gauge, from the extension I had to make.
Then I removed the extension hose from the fitting at the back of the isolator.
This is a cap for a AN-4 fitting that I will use to plug the back of the isolator in case I have to drive the truck tomorrow before I finish removing the gauge. The front of the isolator has fuel going into it, and any antifreeze still left in the back of the isolator would squirt out from pressure on the diaphram in the isolator. I'm replacing the antifreeze in the back of the isolator anyway but just want to limit the mess.
Cap installed. Tomorrow I'll finish the reinstall. That little post sticking out the back of the cap is the flare part inside of the fitting of the cap that matches up with the male flare on the fitting in the isolator. That's what makes the sealing of the cap. I'm pretty sure most of you guys haven't ever seen anything like this, except for some of you retired Airforce guys who worked on planes. This is something any of you may want to use at one time so consider this thread part educational.
