drumvirt
- Feb 18, 2023
- Virginia
- Danny
- C-30
I have an '85 454 Dually w/granny gear and Quadrajet that I occasionally have a problem cooling when I've been driving at highway speeds and outside temp hits about 95 or more. I'm lookin for suggestions and here's what I've learned so far: First, the consensus seems to be that a good electric fan is better than mechanical. Do you agree?
Second, can I wire the fan to continue running for a set time period after the engine shuts off, or, until a temp sensor tells the fan to shut off?
Third, will an electric water pump cool the big 454 better than a mechanical one?
Fourth, can I wire the pump to continue running for a set time period after the engine shuts off, or, until a temp sensor tells the pump to shut off?
Lastly, I don't want to buy a new hood with a scoop to allow the underhood hot air to escape. I'm hoping the other ideas will work.
What do y'all think and what have you tried?
