Ignition problem
irvinc10
US
Irvin
Im having an issue with my 1978 c10 igintion. When i first got the truck, the starter had a wire running inside the cab to start it. Since then ive been trying to figure out why the truck wont start with the igintion switch. When i try starting the truck and leave the switch on the on postition the starter will continue to run.I recently replace the blue ignition switch and it continued to do the same so i doubt that is the problem. I looked at the schematics and it say i need a purple wire at the starter but the one connect has a cream colored wire. Im completely lost as to what i can do to figure out the problem.
Sent from my SM-J727T1 using Tapatalk
dajn37
Minnesota
R10 scottsdale
It sounds like some clown hot wired it. Just be patient and keep studying the internet and you will get it rewired properly again. Just be patient. The answer wont just present itself in front of you. Slowly but surely you will fix this.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
There should be a purple wire with a yellow tracer, or maybe a solid yellow wire) that should go to the neutral safety switch or clutch pedal. Power leaves the clutch or NSS and goes to the starter. I’m guessing the beige wire your seeing was originally pink and has faded or discolored from age. Pink is switched 12volts, used to power the ignition
irvinc10
US
Irvin
Provlem solved. So i did some research and found the image below on the neutral saftey switch, my truck is missing the connector and instead has terminals so the way i had mine setup was different hence why i would get the 12v to the starter on the on position.
iamberttt
