Ignition buzzer
chevyzrule810
Picked up an 85 k10 for parts.What I can't figure out is why the buzzer won't work when the door is open or key is turned to the on position.My 87 did it
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Does it even have the option?
I know in 1985, they went from a buzzer to a chime module and most early chime modules died an early death.
Georgeb
Wisconsin
George
K10 Burb Z71
Does the dome light or courtesy light come on with the door?
chengny
My 86 makes a buzzing sound when the LH door is opened with the key in the ignition - it also buzzes briefly if the seat-belt isn't buckled.
The wiring diagrams for 1985 show that the convenience center had a buzzer for those two alarms. It may be the case that it has simply been pulled from the board. Here is where it should be:
It is GM part 14036201. OEM/NOS is expensive as hell:
1982 – 1992 GM Ignition Lock and Seat Belt Warning Buzzer NOS # 14036201
$95.00
http://www.oldsobsolete.com/product...ck-and-seat-belt-warning-buzzer-nos-14036201/
You could always make your own. Any buzzer or chime wired to a battery lead (e.g. the orange on 140) and out on the 80 pin will work - provided the light green wire to the column, the switch in the column, the tan wire from the key switch to the door jamb switch (and the jamb switch itself) are good.
There should be two ground leads connected to the driver's side door jamb switch. A white one for dome/courtesy lighting and the tan for "key in the ignition".
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I added a headlight reminder buzzer from LMC...my stock unit crapped out.
millernf
