Idling and starting issue
ahoppj
Raleigh, NC
Aaron
Chevrolet k10 silverado
Hey ladies and gents.
just recently had this problem starting that I go to start the truck and it’ll turn after a couple goes. Idles high then it slowly idles down then turns off. Any ideas?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Carb? Tbi?
Also welcome lol.
I'm in Salisbury.
Vbb199
Salisbury NC
Vince
Have you tuned the idle screws yet?
Taylorb27
North Dakota
Sounds like you may have developed a vacuum leak. Big enough to need idle mixture screws adjusted. It's firing off the accelerator pump shot and once that runs out it leans out so bad that it dies.
If your timing is right start by turning the idle mixture screws out a half turn then see how it responds.
What carb is on this?
ahoppj
Raleigh, NC
Aaron
I also did just replace the valve covers and replaced the pcv valve with a breather. Could that be it ?
ahoppj
Raleigh, NC
Aaron
Or I just need to adjust the screws because I took out the pcv valve hose
Taylorb27
North Dakota
Just make sure the pcv hose isn't dry rotted or anything and that pcv, although new, works like it should. Also make sure the grommet that the pcv goes in is still sealing as it should.
If you're concerned about that just cap off that port and run it. If it runs fine that's your issue, if not, hook the hose back up after checking it out and look elsewhere
Taylorb27
North Dakota
Oh sorry I read that wrong, you replaced it with a breather. I personally recommend you put the pcv back in. And make sure you capped the port or plugged the hose that went to the old pcv
Taylorb27
North Dakota
If you left the pcv port or hose open that is a major vacuum leak
ahoppj
Raleigh, NC
Aaron
Taylorb27
North Dakota
The arrow is pointing to around the area where that pcv hose should hook up, as I'm sure you know. Make sure that is capped since there isn't anything running to it
ahoppj
Raleigh, NC
Aaron
Alright I plugged it up and now it’s just idling really low... who wants to give me the tutorial on the isle screws :). I could look it up on you tube but I’d rather talk to you guys
Taylorb27
North Dakota
I'd recommend you get a vacuum gauge and do your fine tuning. For now you can just bump up your idle speed slightly to get to where you want it.
Basically on the mixture screws I start by bottoming the mixtures screws out and then backing them off 2.5 turns. Start the engine and get it to temp. Then look at the vacuum gauge and adjust in or out until I get the highest vacuum I can on the gauge.
This is assuming your timing is on where you want it. Then after this recheck timing again
ruggedly
