I need HELP!! Lights switch and ignition??
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
89Suburbsn - tomorrow I will go get some nice large gauge wire and rewire the alernator the way you suggest. I will also replace the negative wire of the battery with a beefier one. Again, thanks to everybody for all the help.
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
I removed a ton of rotten insulation material from under the carpet... Do you know where I can buy some to replace it? What do you even call that stuff??
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
This one is for you! I have lights and a working truck. Thanks!!!
texnet
Ronnie
The original stuff is called Broom Mat... http://www.eastwood.com/dei-under-c...la&utm_medium=Merchant-Centre&SRCCODE=1SE1532
A lot of folks use a more modern material called HushMat http://hushmat.com/?gclid=COafktn6y8ICFataMgod10EAtw
There are several other types/brands of products on the market.
P.S... glad you found a temporary fix for the electrical problem. Don't leave it temporary for too long :)
dot4x4
Cottonwood CA
scott
c10 Silverado
Glad it worked out for you. Good luck with getting a permanent fix.
chengny
The carpet underlay material is called "jute".
If you plan on stripping all the old stuff out, it would be wise to try to salvage the catalytic converter insulation pads - white material in clear plastic bags - if you have them.
Good job! :waytogo:
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
I just got the lights wiring upgrade kit...
Sent from my iPad using Tapatalk
scawdrey
