I need HELP!! Lights switch and ignition??
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Hello everybody, thank you for reading this.
I'm new to the forum, I've had my first truck for about one year, it is a 1987 Custom Deluxe 5.7 V8 4x4. I've had a problem for a few months, which is the engine would die when you turn the lights on. Then it would take anywhere from one to ten minutes to start again. I did some research and thought that the negative wire of the battery was bad. So I replaced that. I thought I solved the problem because the problem disappeared for a few weeks. The other day it did it again. So I thought it might be a bad light switch. I ordered a new one and I just replaced it. The funny thing is that:
1- when I removed the original the lights stayed on. It took me about 15 minutes to replace it. I was alone so I thought, worst case I'll have to recharge the battery.
2- sometime while I was under the dash cussing the lights stopped working.
3- I replaced the switch, tried to start the truck and it cranks fine ( so the battery is working) but the engine doesn't fire up.
4- no light is currently working. I swapped the switch with the old and sa e problem: no lights and the engine cranks fine but doesn't start.
I'm lost. Any ideas??
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
The more I think about this, the more I think it is some sort of a coincidence. How do you check if the fuse box is well connected? Can it be a short I. The light system? What can completely kill all the lights and still getting the engine to crank and not fire up?
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
I just checked (in the dark with a maglite) and the wire connectors on the engine side on the firewall are completely covered in dust and very brittle... How difficult it is to rewire one of these trucks??
350runner
tx
Ceasar
It's only hard as you make it :) it really sounds like something in the light system is grounding out. @chengny usually has some insight on things like this.:)
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Thank you!! I'm really depressed right now....I can tackle any mechanical problem but electrical problems really scare me...and I can't take the truck to a shop if it doesn't start.... Since it got dark outside, I could not see very well so I used my iPhone to shot some random pictures under the dash to get an idea of the situation and it does not look pretty. That is when I started thinking about replacing the entire wire harness....
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Boone83K10
Boone, NC
Benjamin
Your fuse box doesn't look any different than every other pic of a fuse box I have ever seen of these trucks. Really you should take a pic of the wires at the light switch, then we can go from there.
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Here it is:
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
And this is the wire connection on the firewall:
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
I did spray some wire dryer on these
350runner
tx
Ceasar
This is normal. GM used that gooey stuff as a sealant :).
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Tomorrow I have time to work on it... I need to start testing wire by wire?? I do have a test meter. One of the many things that doesn't make sense to me right now is: if it is a short somewhere...shouldn't it just blow a fuse? Are ALL the lights on the same circuit?
350runner
tx
Ceasar
Start with the light circuit unplug the head lights then pull the head light switch out to the on position. Are you still having this issue? I'll check back tomorrow..
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Thank you for the help!!!! I really appreciate it!!!
builder100
