I have a stupid question about valve covers
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
My valve covers leak oil like crazy, so I decided I'll replace covers and gaskets instead of trying to make sure my covers aren't warped and seal good. Given that I'm pulling all of the emissions stuff out of it, here's my stupid question:
What valve cover should I buy? By that I mean do I need the ones with one hole or 2 holes? And do I need to put a breather on them? I've seen some people have them and some don't. I'm still new to this truck thing, so I'm learning slowly.
Skweegle89
Oklahoma
You need a hole in one side for the PCV valve and need to run a breather on the opposite side. The breather hole can double as your oil fill hole if you want.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Skweegle89
Oklahoma
I don't see why not. Check Amazon first though. Everything is cheaper from Amazon, and you can find those same covers there.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Thanks. I'm just looking at advance because I've got some store credit to burn.
Skweegle89
Oklahoma
Well then heck yea. Just make sure to look at the obvious things, like that you have the perimeter bolts and not covers that bolt through the middle, and obviously that they will fit an sbc. Now might also be a good time to replace the PCV Valve and the rubber bushing that it goes in. They are only like $5.
firebane
Calgary, AB
Curtis
Skweegle89
Oklahoma
Don't torque your bolts down too tight. Just snug. Fel pro makes some good cork gaskets for them if your covers don't already come with some.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Awesome. Thanks for the help guys.
rich weyand
Bloomington Indiana
Rich
Then use these gaskets. Rubber with a steel core so they won't shift.
http://www.jegs.com/i/JEGS+Performance+Products/555/21100/10002/-1
And seal them with this. Clean both mating surfaces with lacquer thinner, then rub it in to both sides of the gasket and both mating surfaces, leaving a very thin layer.
http://www.amazon.com/T2566-Medium-Weight-Sealing-Compound/dp/B005NK45QM
Use some kind of pressure spreaders. I used both of these, the small ones on top of the hoops to add rigidity.
http://www.jegs.com/i/Trans-Dapt/969/4992/10002/-1?parentProductId=1619271
http://www.jegs.com/i/Proform/778/66292BKC/10002/-1?parentProductId=746299
I also used T-nuts, which I tighten finger-tight, so as not to overtighten them.
http://www.jegs.com/i/Spectre/865/5320/10002/-1
Overkill? Perhaps. But the damned things don't leak any more.
12turnda
